68 mustang frame restoration - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2006, 03:27 PM
any ideas?
Old 06-21-2006, 07:08 PM
30desoto's Avatar
Dodge ain't all bad
walkn slow
I got to say that this is pretty vague. If you want to do a complete restoration you start with taking the whole body off, engine out trans out and start your cleanup and replacement of rusted area's. strip down to bare metal repair what needs it then epoxy primer and paint (your choice of paint bc/cc or single stage) good luck and welcome.
By the way you need to get more in detail with your questions and you will find that you will get more responses.
30dee
Old 06-22-2006, 10:56 AM
Wiki Edits: 49
To begin with, if I'm not mistaken, your Mustang is a unibody so the only "frame" you really have is the front clip.
If you want to do your restoration correctly, as has been mentioned, you'll have to disassemble the entire car and start from the bottom up fixing whatever problems you find along the way.
Good luck.
Old 06-22-2006, 03:32 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Originally Posted by walkn slow
any ideas?
Spend what it takes to start with a rust free southern or western car. You will be glad you did.
59 Chevy pickup frame woes! Li'l Pine Suspension - Brakes - Steering 33 07-08-2009 08:24 PM
86 s-10 frame bent catscan4free Suspension - Brakes - Steering 3 03-27-2007 09:46 PM
How to start a 68 Mustang after storage of 10 years. 68pony5 Engine 8 06-07-2006 12:18 PM
Critique My Frame STATUTORY GRAPE Suspension - Brakes - Steering 23 12-21-2005 08:51 PM
sub frame attachment Ricky Rocket Suspension - Brakes - Steering 4 09-18-2005 09:59 PM
