Nope----still need 2 relays.
If you use 87a on the relay for anything---there is no way to shut off the lights. Wire it just like that diagram I posted in the other thread. (not at home now, or I would re-attatch the pic) When you turn on your lights--this energizes the relay coils (s) thru the dimmer switch (relays power from #30 to #87). When the lights are shut of and NO power is going to the relay coil, #87a will be connected to #30. 87a would be used for something like remote controlled doors or button operated doors. This way the doors would operate when the the key is NOT in the ignition (off), and would break the power to the doors when the key is in the run position. This is a safety thing (that I am NOT using on the 59, as it has inoperable door handles). Just using the doors as an example |
I think I would setup a separate relay for high and low beams. Feed the relay activation off of the current feed wire for the low and high beams. This way the only wiring to be modified will be right out by the lights and will be easily reversible in case you or someone else ever wants to go back to stock. This wil also prevent a single relay failure killing both high and low beams.
Chet |
p.s. my elks headlights are much much brighter and ive noticed better power to everything else. the nice part is when i have my stereo on blinker blinking and the headlights on i barley see a drop in my volts. |
yay!!! bright mustang lights!!! but ones brighter than the other. . . idk how or why but one headlight is halogen and the other is incandescent
. i told my sis shes gotta buy new halogens. a match pair. anyways thanks for all the help yet again
| what is the fastest (factory) car you have ever driven? | badknuckles | Hotrodders' Lounge | 320 | 12-09-2011 01:32 AM |
| transmission for 68 mustang | wannadrivemystang | Transmission - Rearend | 1 | 08-29-2007 07:25 PM |
| How Does This Stuff Work? | docvette | Electrical | 3 | 06-18-2006 03:00 AM |
| '68 Mustang 200 CID | o.kisutch | Engine | 5 | 02-11-2006 05:38 PM |
| '68 mustang with '69 one piece glass???? | nightMARE | Body - Exterior | 1 | 02-27-2004 12:14 AM |
