68 Olds 350 rebuild questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2011, 02:15 PM
Hi All,
Pulled the engine yesterday. It is a 68 Olds 350 Cutlass Convertible 2bbl, Jetaway Tran. Want to stay mostly stock but want to beef the motor up a bit. I want to swap to a 4bl, a little bigger than stock cam and headers. I want off the line power with a noticeable idle and street driveabilty. ANy suggestions for cam kit, intake and carb? I have the #5 heads so good flowing, any advantage to shaving them .10 or .20? Chasis is being redone too with all new polyurethane bushings etc.
thanks,
S.
Old 10-17-2011, 07:35 PM
Hot Rod Has Been
If you like a lumpy idle a lot of guys get the "Thumper" series cams from CompCams...
Old 10-17-2011, 09:11 PM
bigdog7373's Avatar
Of course it's fast
No! He said Off the line power, and drivability. The thumpr gives neither of those. Its all sound, no performance and will give you problems when trying to tune it.
Old 10-18-2011, 03:37 PM
techinspector1's Avatar
Wiki Edits: 326
You can't intelligently choose a cam until you know the exact static compression ratio of the motor. To know that, you'll have to do some measuring with precision instruments and pouring of volumes with a burette.
Take a look at this build....
http://www.mondellotwister.com/ArtOthr350s.htm
Old 10-18-2011, 06:03 PM
BOBCRMAN@aol.com's Avatar
Also. if you plan on making power on the street. You will need more head work. Hardened seats placed in the exhaust side and good exhaust valves. Most any pre -73 GM engine has soft seats not compatible with todays fuel.
Old 10-19-2011, 12:53 PM
Oh yeah, all the crappy idle of a long overlap cam with none of the pesky extra horsepower...
Old 10-20-2011, 04:05 PM
Hot Rod Has Been
I didn't say I recommended the Thumper cams... just mentioned them. Personally I'd choose almost anything except one...
Old 10-20-2011, 04:38 PM
bigdog7373's Avatar
Of course it's fast
Sureeeee
Old 10-22-2011, 09:36 AM
Hot Rod Has Been
Sureeeee
I had my Hemi blower cam custom ground by George at Clay Smith... he furnished a cam that was a whole lot different than any of the off the shelf units. I wanted a smooth idle and a good low end... kinda like my old girlfriend.
Olds 403 6.6L rebuild...need help 79TransAmMan Engine 14 03-15-2011 10:41 AM
455 Olds Rebuild JSBal59 Engine 5 07-22-2010 07:19 PM
403 Olds rebuild TommyV_11 Engine 42 10-26-2009 08:10 AM
350 olds rebuild 86 442 cutdog Engine 8 03-07-2007 07:36 PM
394 Olds rebuild spankyway Engine 0 01-31-2004 05:15 PM
