Hotrodders Bulletin Board > Tech Help> Engine
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 10-09-2005, 07:42 PM
68 olds 68 olds is offline
68 olds
need to now some old school tricks to bump up the horses got any ideas ??????????
Old 10-09-2005, 09:20 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Horses
Doc here,
Without any exotic Rebuilds, and going low budget, the best shot Engine wise is:
Mild Cam, New Carb or rebuild what you have, Full tune up..(all new stuff even if it looks OK) New fuel filters, A COLD AIR pickup for the air cleaner and low flow filter, Headers and low back pressure Exhaust (your choice on brand)Install an HEI ignition, 8.5 MM spiral core wires (for the new HV spark) and gap plugs at 45 instead of 35.. You could do NOX, but remember that engine IS 37 years old..use it sparingly..
With just that, you should notice a BIG difference in getum up go..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-10-2005, 05:01 AM
73oldsman's Avatar
73oldsman 73oldsman is offline
Good info from Doc! There's also some good Olds info here...http://www.mondellotwister.com/articles.html and http://www.dickmillerracing.com/
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "68 olds"
ThreadThread StarterForumRepliesLast Post
what is the fastest (factory) car you have ever driven?badknucklesHotrodders' Lounge32012-09-2011 02:32 AM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'EngineOldsmolac911Hotrodders' Lounge5001-12-2011 11:00 PM
68 olds68 oldsIntroduce Yourself210-09-2005 08:35 PM
68 olds 442bear1968Electrical201-22-2005 11:17 PM
68 olds cutlass brake conversionJeff SaterSuspension - Brakes - Steering209-03-2003 09:20 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
