68 power steering
I have a 1968 Camaro, originally a standard coupe with a
six cylinder and a power glide. The VIN# is 123378L303966. I now have a 383 stroker with a Turbo 400. I have always had clearance problems with my Flowtech Afterburner long tube headers(1 1/2 inch primaries, 3 inch collectors) rubbing against the stock power steering gear box. The number 3 tube would rub and create an awful loud vibration at low rpm but would usually go away once I'm up to speed. I recently upgraded my cast iron SR Torquer heads to the GM Aluminum Fast Burn heads. Because of this upgrade, I also had to change my headers. I ordered a set of Hedman Shorty headers from Jet Hot with 1 5/8 inch primaries and 3 inch collectors. Now I can't even move the header into place to bolt it in because the number 3 tube hits the power steering box even worse than before. Is there a smaller power steering gear box that I could swap over to that would give me the room I need to bolt the header in place? I thought I read somewhere about either an aftermarket gear box for a Nova that would work, or a third or fourth generation gear box that would be smaller. If not, does that mean I'll have to convert to manual steering, and if so, would that fix my clearance problem? I know I've consistently read about guys with headers even bigger than mine that have power steering and it looks like they have plenty of room. Any help you can give would be great! Thanks! Earl Brunson Pensacola, FL ebrunson@ureach.com |
Earl ...I'm not going to be much help to you here, but I think your looking at this problem all wrong. The power steering is not the problem, it's your headers! I have a 69 vette and had a set of Hedman headers also. The headers rubbed on the steering box! Until I finally changed them out with another set of headers (Hooker's) ...the problem went away! I'm not sure you can return your headers, but I would try. Don't end up trying to make "poor quality" work! My $0.02, Good Luck! ...Mark
68 power steering
Thanks for the suggestion, but I'm still wondering about the gear box since I had the same problem with Flowtech Afterburner headers. Those just barely fit, but still rubbed. They were 1 1/2 inches, my Hedman's are 1 5/8 inches. I opted for the Hedman's instead of Hooker's because of the setup with the Fastburn heads, they were the only one's guaranteed to fit. Plus I'm not sure if Jet Hot will take them back since they are scratched up from the gear box. I guess I'll just keep trying to figure it out!
I've been building camaros since day one and I don't know of any other stock type sector that fits. Have had some guys tell me they used the later model ones, but had some kind of ratio problems.
Any header is very close to the sector. some will fit and some will not, most will not. I gently massage the tube to get about a 1/4 inch clearance. I have even bolted them to another engine in the floor and sprung them enough to get some clearance. Good Luck Troy __________________ If you don't make mistakes. your not doing anything. 69 ss rs full custom camaro 98 ISCA grandchampion 69 ss rs bb camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 ss chevelle bb conv.fresh frame off 26 T sedan street rod |
massaging headers
What's the best way to massage the header pipe to fit around the steering gear box?
That's a nice way of saying....Hit it with a hammer................
| All times are GMT -6. The time now is 09:44 PM. |
