Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 04-03-2004, 05:44 PM
burner burner is offline
68 power steering
I have a 1968 Camaro, originally a standard coupe with a
six cylinder and a power glide. The VIN# is 123378L303966. I
now have a 383 stroker with a Turbo 400. I have always had
clearance problems with my Flowtech Afterburner long tube
headers(1 1/2 inch primaries, 3 inch collectors) rubbing against
the stock power steering gear box. The number 3 tube would rub
and create an awful loud vibration at low rpm but would usually
go away once I'm up to speed.
I recently upgraded my cast iron SR Torquer heads to the GM
Aluminum Fast Burn heads. Because of this upgrade, I also had
to change my headers. I ordered a set of Hedman Shorty headers
from Jet Hot with 1 5/8 inch primaries and 3 inch collectors.
Now I can't even move the header into place to bolt it in
because the number 3 tube hits the power steering box even worse
than before.
Is there a smaller power steering gear box that I could swap
over to that would give me the room I need to bolt the header in
place? I thought I read somewhere about either an aftermarket
gear box for a Nova that would work, or a third or fourth
generation gear box that would be smaller. If not, does that
mean I'll have to convert to manual steering, and if so, would
that fix my clearance problem?
I know I've consistently read about guys with headers even
bigger than mine that have power steering and it looks like they
have plenty of room. Any help you can give would be great!
Thanks!
Earl Brunson
Pensacola, FL
ebrunson@ureach.com
Old 04-06-2004, 09:33 AM
11echo's Avatar
11echo 11echo is online now
Old Guys Rule!...EVERYTHING!
re: 68 power steering
Earl ...I'm not going to be much help to you here, but I think your looking at this problem all wrong. The power steering is not the problem, it's your headers! I have a 69 vette and had a set of Hedman headers also. The headers rubbed on the steering box! Until I finally changed them out with another set of headers (Hooker's) ...the problem went away! I'm not sure you can return your headers, but I would try. Don't end up trying to make "poor quality" work! My $0.02, Good Luck! ...Mark
Old 04-06-2004, 05:00 PM
68 power steering
Thanks for the suggestion, but I'm still wondering about the gear box since I had the same problem with Flowtech Afterburner headers. Those just barely fit, but still rubbed. They were 1 1/2 inches, my Hedman's are 1 5/8 inches. I opted for the Hedman's instead of Hooker's because of the setup with the Fastburn heads, they were the only one's guaranteed to fit. Plus I'm not sure if Jet Hot will take them back since they are scratched up from the gear box. I guess I'll just keep trying to figure it out!
Old 04-06-2004, 06:49 PM
troy-curt's Avatar
troy-curt troy-curt is offline
Shop Owner And Troll Hunter
I've been building camaros since day one and I don't know of any other stock type sector that fits. Have had some guys tell me they used the later model ones, but had some kind of ratio problems.
Any header is very close to the sector. some will fit and some will not, most will not. I gently massage the tube to get about a 1/4 inch clearance. I have even bolted them to another engine in the floor and sprung them enough to get some clearance. Good Luck
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 04-06-2004, 08:10 PM
massaging headers
What's the best way to massage the header pipe to fit around the steering gear box?
Old 04-06-2004, 08:20 PM
poncho62's Avatar
poncho62 poncho62 is offline
Moderator
 poncho62's barnstar
Wiki Edits: 5
That's a nice way of saying....Hit it with a hammer................
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
