69 428 Pontiac dip stick - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2006, 07:58 PM
I got this engine in my shop and the outside dipstick tube is rotted off about 6 inches above the oil pan rail where it goes through the block, There is a short curved one about 5 inches long that inserts into this one from the bottom and extends through the windage tray into oil pan.
Now I purchased one on E-bay that was supposed to fit , but the bottom of the tube is too fat to insert into the block, called dude and he said the stick and tube I bought was supposed to go over the rotted off piece on the outside but it is is not large enough on the ID to go over what is left.
Does anyone have any knowledge of this setup , pictures , etc.
Would appreciate any help , cant install pan until I get the stick ironed out
Old 05-27-2006, 06:00 AM
On Pontiac engines the oil tube can only be installed from the inside of the engine, meaning the oil pan has to be off in order to install a new tube.
Old 05-27-2006, 08:55 AM
I've got the pan off , that s the dilema , I need to know just how many tubes make up this thing, like I said there is a short one inside that fits up into the one on the outside, I have driven that one out but , it was rotted away about 6 inches above where it goes into the block.
Now I am assuming that the one on the outside is one piece , it goes from the oil pan rail where it enters the block up to where the dip stick fits into it.
That is my belief , but I never saw it before it came to my shop, the dude that sold me the new one say's it is two pieces on the outside.
Old 05-27-2006, 12:22 PM
If the engine has the brackets in place for air conditioning the there is another tube that goes onto the one the goes into the block. Then the short curved one goes in the other end and down through the windage tray otherwise the dipstick will not go down into the oil pan, it'll catch on the tray.
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
69 Pontiac YH 428 for sale! drewhelm Engine 10 02-05-2009 07:46 PM
69 bonneville 428 engine klingler69 Engine 0 09-20-2005 04:40 PM
428 pontiac heads 72 Z28 Engine 5 12-04-2003 08:19 AM
a 69' el camino with a stick shift? kickinit Transmission - Rearend 2 08-10-2002 11:42 PM
