69 C10 IL6 to V8 Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2011, 08:51 AM
I see alot of these swaps but most have the engine set too far back.
What is the correct placement measurement from the rear of the valve cover on the drivers side to the fire wall?
Old 06-18-2011, 04:03 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Correct in my world would be where you can get the valve covers, exhaust manifolds/headers, intake manifold and distributor cap off the motor when it's in place. My other concern would be positioning of the radiator so that the engine-driven fan blade would be within one inch of the radiator core and that a full shroud could be fitted.
Old 06-18-2011, 05:21 PM
I guess I should have said 'Factory' placement. Anyone have a C10 with a factory installed V8 ? 67 to 72.
Old 06-18-2011, 07:47 PM
SSedan64's Avatar
You should upgrade to the 73-87 style frame mounts, the old style are a pain to work with.>> http://67-72chevytrucks.com/vboard/s...d.php?t=128765
LS1 Carb Swap and Cam Swap. Hacksaw Engine 26 06-30-2011 10:36 AM
456 gear swap to 373 in 8.5 rearend, carrier swap? leslie61 Transmission - Rearend 3 07-19-2009 03:45 PM
Tranny swap/ rearend swap? aggar Transmission - Rearend 2 03-16-2008 03:07 PM
86 K10 engine swap! swap tranny too? big_e111 Transmission - Rearend 3 08-03-2007 01:21 PM
to swap or not to swap? 78 Nova for a 75 wayfast77 General Rodding Tech 3 01-26-2007 06:33 AM
