-   -   69 c10 rear coil spring lowering (http://www.hotrodders.com/forum/69-c10-rear-coil-spring-lowering-231526.html)
Claude OD 04-05-2013 03:12 PM
I ahve a 69 c10 short bed step side with coil springs. Want to lower it 3 inches in back...The front is already lowered. Can I just buy 3 inch lowering coils and install them?
Valkyrie5.7 04-05-2013 03:35 PM
http://67-72chevytrucks.com/vboard/a...1&d=1334166393
Same rear suspension as your 69, with springs from a Jeep TJ in the back. clipped 1.5 coils in front. Should get you close to your requirements.
gearheadslife 04-05-2013 03:45 PM
YES AND NO..
easyest way is listed above..
but you'll need to get the angled shims to get the pinion angle correct..
many vendors sell them for these truck(aka nascar )
I made blocks.. with 2.5" 1/4" thick square tube
http://i683.photobucket.com/albums/v.../P10002332.jpg
Claude OD 04-05-2013 09:16 PM
Thanks. Am going to the Charotte Auto Fair tomorrow. Will see what I can find.
