-   -   69 cadillac gearbox question (http://www.hotrodders.com/forum/69-cadillac-gearbox-question-223032.html)
tonupkid 08-18-2012 12:56 PM
hello guys
i got a 69 eldorado(fwd) and i want to rebuild it to a rwd, it has a 472 engine,i was looking for a gearbox for the engine and came up to a TH400 out of a 72 buick riviera, would this fit my 472 engine??? i read before that TH350 and TH400 would fit but i dont know if this is true, any sugestions of gearboxes i can use?
thanx pete
WDCreech 08-18-2012 01:43 PM
Originally Posted by tonupkid (Post 1583924)
hello guys
thanx pete
Cadillac had the BOP bellhousing bolt pattern, so that Buick TH400 will bolt up, as would any TH350/400 that has the BOP bolt pattern.
tonupkid 08-18-2012 02:26 PM
ok,problem solved then!:) thanks a lot for the info WDCreech!!!
tonupkid 08-18-2012 02:29 PM
what type of rear axle would be a good combination with that engine/gearbox?
WDCreech 08-18-2012 04:27 PM
If you plan on abusing it, Dana 60, Ford 9", or Chevy 12 bolt, or an 8.5" 10 bolt might suffice.
Bill
tonupkid 08-19-2012 12:12 AM
thanx a lot bill !:thumbup:
AutoGear 08-20-2012 07:31 AM
There was a guy around Syracuse years ago that had a Toronado drivetrain stuffed into the back of his late 40s/ early 50s Desoto. It was pretty well done from what I remember and would just shred tires. However I have no pictures, nor any idea what happened to it or the owner.
