69 cadillac gearbox question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2012, 12:56 PM
hello guys
i got a 69 eldorado(fwd) and i want to rebuild it to a rwd, it has a 472 engine,i was looking for a gearbox for the engine and came up to a TH400 out of a 72 buick riviera, would this fit my 472 engine??? i read before that TH350 and TH400 would fit but i dont know if this is true, any sugestions of gearboxes i can use?
thanx pete
Old 08-18-2012, 01:43 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Originally Posted by tonupkid View Post
hello guys
thanx pete
Cadillac had the BOP bellhousing bolt pattern, so that Buick TH400 will bolt up, as would any TH350/400 that has the BOP bolt pattern.
Old 08-18-2012, 02:26 PM
ok,problem solved then! thanks a lot for the info WDCreech!!!
Old 08-18-2012, 02:29 PM
what type of rear axle would be a good combination with that engine/gearbox?
Old 08-18-2012, 04:27 PM
WDCreech's Avatar
If you plan on abusing it, Dana 60, Ford 9", or Chevy 12 bolt, or an 8.5" 10 bolt might suffice.
Bill
Old 08-19-2012, 12:12 AM
thanx a lot bill !
Old 08-20-2012, 07:31 AM
There was a guy around Syracuse years ago that had a Toronado drivetrain stuffed into the back of his late 40s/ early 50s Desoto. It was pretty well done from what I remember and would just shred tires. However I have no pictures, nor any idea what happened to it or the owner.
46 Cadillac Body Question MXrider13 Body - Exterior 3 07-29-2012 10:12 AM
Cadillac Restoration Question The Punisher Hotrodding Basics 2 05-22-2008 08:00 PM
72 Cadillac Question EazyDuzIt102 Engine 4 05-31-2006 09:33 PM
Introduction and Clutch, Gearbox Question Alex Wild Introduce Yourself 2 03-22-2006 01:11 PM
Hello!! I Have a CADILLAC Question? MsCadillacLovely Interior 2 12-14-2004 09:04 PM
