69 Camaro 12 Bolt Posi - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2009, 02:18 PM
Help out there! I'm getting the parts together for my 69 Camaro build and I am looking for a 12 bolt posi rear end @ 4.10 gears or a little lower. Does anybody know what other rear ends will work with the 69 and by chance does anyone know someone with one for sale? Thanks
Old 10-31-2009, 11:35 AM
12 bolt posi.
Hello,I see that you are looking for a 12 bolt,I know that is the rear end people love because they are a bit heavier duty than the stock 8.2 10 bolt,but unless you are putting something with over 500 hp in the front of this thing,the 10 bolt is easier to find,cheaper,and more readily available to the public.You can upgrade the axles on the 8.2 and also get a set or richmond gears fro the price of a 12 bolt case alone these days.
I know I may catch some grief for this posting,but having my own 68 and 76 Firebirds, I know how hard it can be to find a 12 bolt on a budget. My 10 bolt 3.42 works just as well as any 12 bolt..
Old 10-31-2009, 02:26 PM
302 Z28's Avatar
12 Bolts to fit early Camaros (67-69) are in high demand right now and command premium prices. Everyone with a 67-69 Camaro want's to make it a Z/28 or an SS. The 12 bolt from early Nova's is the same thing, but again they only came on HiPerf Nova's.
Vince
Old 11-01-2009, 07:07 AM
12 Bolt Looking
Thanks for the input guys. I'm pretty sure I will need a 12 bolt. The engine going in my 69 is a 408 Stroker that dynoed at 575 HP and 530 FtLbs at 5200 RPM. If all else fails I suppose I could take out a second mortgage and purchase a new one? (Ouch) I'll keep looking. If you hear or see one come available give me a shout.
Thanks
Old 11-01-2009, 07:13 AM
12 Bolt Question
If you were going to purchase new; would you go with Moser, Strange, Currie, Dana, or ? All input is welcome.
Thanks again!
Old 11-01-2009, 06:45 PM
302 Z28's Avatar
If I was going to purchase new for what you are doing I would buy a new Ford 9" housing and third member for your Camaro. They are superior to a 12 bolt in strength and far easier to swap gears in.
Vince
Old 11-01-2009, 07:33 PM
ericnova72's Avatar
More for Less Racer
Thanks
At that power level, a decent prepped 8.5" 10-bolt from a 72-up Nova will fill the bill. Upgrade to 30 spline axles and diff, add a rear girdle cover and pick your gears.
12 Bolt Posi ID Help BigBlockTony Transmission - Rearend 1 09-02-2009 03:36 AM
68 Camaro 12 bolt decode needed ronnied Suspension - Brakes - Steering 6 09-08-2005 11:03 AM
What to upgrade on a 12 bolt Posi Elevinpointsixtoone Transmission - Rearend 12 01-10-2005 05:53 PM
How to identify Oldsmobile 12 bolt? elukas Transmission - Rearend 8 12-13-2003 10:59 AM
12 Bolt Posi identification 66chevySS Transmission - Rearend 1 12-09-2002 09:56 PM
