69 camaro 5 spd conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2003, 06:34 PM
Post 69 camaro 5 spd conversion
starting from scratch on 69 camaro 3 speed 6 cyl car. i have 70 350 and would like to put a 5 speed behind it. need help on donor cars, articles,parts sources, pointers etc. i need bellhousing, linkage, crossmember etc thanks for any help any direction
Old 05-22-2003, 05:48 PM
DoubleVision's Avatar
Post
although I`m not sure of what all 5 speeds are avalible, but if your running a stock 350, with not a lot of power and don`t intend on thrashing it, a T-5 will live, you could likely find a 80`s era Camaro with a 305 and a T-5, you should be able to do some fabrication to get it over into your car. but keep in mind, T-5`s can`t take high power and abuse, a friend of mine found this out after I had told him many times, he lost a few gears and a tranny shop wanted $2000 to fix it,, ouch.
