Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 Camaro Cluch Fork Hits Firewall...
Old 07-07-2004, 04:52 PM
FiefSS FiefSS is offline
CamaroX
gah if height is the same what else should I be looking at.... cause something is about 3/8ths to an inch to high somewhere, and the motor mounts, frame mounts and trans mount are the correct ones for the car. something has to be incorrect somewhere as the motor and trans need to be just a bit lower and everything clears...
