Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 Camaro Cluch Fork Hits Firewall...
Old 07-16-2004, 02:04 PM
daveh's Avatar
daveh daveh is offline
I had the same problem with my 69 Z and it ended up that the clutch fork pivot ball was too long. Get a short pivot ball and you will be fine. I thought making it longer was the trick but it needed to be shorter. Good luck.
