Hotrodders Bulletin Board
#1
69 Camaro dimmer switch problems
Hi folks!
This is my first visit to this site. When I hit my dimmer switch to go to high beams my lights cut out all together (no lights at all). I have replaced the dimmer switch twice and checked the wires and they look O.K. Any ideas? Thanks!! |
#2
If the wiring is good and the switch is good. then the high beams must be burned out. Check the ground. Good Luck
Troy __________________ If you don't make mistakes. your not doing anything. 69 ss rs full custom camaro 98 ISCA grandchampion 69 ss rs bb camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 ss chevelle bb conv.fresh frame off 26 T sedan street rod |
#3
pull a head light and stick a voltage tester onto the lead to the high beams. if you got 12Volts you gottum bad lights. my guess is you wont have voltage and have a bad dimmer switch although if you have the wiring wrong it wont work either. you have a hot to the switch then two wires to the head lights that take turns going on and off.
