69 Camaro - few questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2006, 05:25 PM
My friend has a 69 Camaro that we are starting to restore. It doesn't run right now, and doesn't have a front subframe at all.
He said he thinks you can bolt a late-model (3rd or 4th) generation Camaro/Firebird front subframe into a 1st generation camaro.... I find that very hard to believe... anyone know if this is true?
Also, for the rear subframe/suspension, on the 1st gen camaro, aren't the frame rails welded to the car? Isn't that called a Uni-body or something? My friend seems to think that he can "drop" the rear subframe because it just unbolts from the car.... I find that hard to believe also.
Thanks,
Sean
Old 07-21-2006, 05:55 PM
Your friend is wrong ... on both counts ...
Old 07-21-2006, 06:18 PM
Wiki Edits: 31
nope, he's gonna need 1st gen stuff. I belive it's available in the aftermarket
Old 07-21-2006, 08:34 PM
302 Z28's Avatar
As stated in the previous post, you need all first gen stuff, and a friend that knows early camraro's . Some early 68-69-70ish Nova stuff will transplant.
Vince
Old 07-21-2006, 08:50 PM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
Ya, 67-69 F-body and 68-74 X-body subframes will interchange. And, yes, the rear frame rails are welded on and are part of the unibody.
Hemi in a 69 Camaro? Fil Hotrodding Basics 149 12-28-2010 02:52 PM
69 camaro fuel sending unit ?'s studeman Engine 3 05-19-2006 05:33 PM
" New" 69 Camaro zonk Hotrodders' Lounge 2 01-19-2006 07:53 PM
The first 69 Camaro built for competitive drifting ChevelleSS_LS6 Hotrodders' Lounge 20 11-16-2005 06:43 PM
'36 P/U, 69 Camaro subrame engine help!!! Apathy93Z Engine 1 12-08-2004 06:54 AM
