69 Camaro heater conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2003, 05:58 PM
Post 69 Camaro heater conversion
I'm building a 69 Z-28 clone from a standard 350 air conditioned car. I want to replace the air conditioning system with a standard Camaro heater system. Can anyone give me some leads as to where I can find all the parts I need to make the conversion. There seems to be lots of air conditioning parts available, but not much for the heater car. I'm aware there will have to be some firewall mods for the heater unit.
Thanks for any help.
Old 02-17-2003, 11:02 AM
New Member
Post
i dunno if things have changed but when i was building a 68 camaro a/c car i couldnt find anything...i gave up and blocked off the hole in the firewall w/ an aluminum panel and just drove it w/o heat or a/c.
Old 02-25-2003, 10:12 AM
Post
You can find all the parts you need from national parts depot or classic industries.
Old 08-15-2012, 08:07 AM
Jeff J's Avatar
69 Camaro
hello, I am trying to rebuild, replace my stock*********************************** My car originally had a/c but not much is left other than the stuff under the dash. Thanks in advance, good luck on your project. Jeff
Last edited by poncho62; 08-18-2012 at 05:12 AM. Reason: classified ads not allowed...use the classified section...thanks
Old 08-15-2012, 07:06 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Moving this to General Rodding Tech.
Dan
Old 08-16-2012, 10:02 PM
RWENUTS's Avatar
Jeff.
The thread is 10 years old. Chance of an answer is slim to none!!
Old 08-17-2012, 02:02 AM
Jeff J's Avatar
10 years old, Ha !! Wow, didn't know that or i didn't look, thanks Jeff
Old 08-17-2012, 09:13 PM
RWENUTS's Avatar
The date is right there in the top left hand corner if every post.
