Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 camaro ignition switch loses power, pics.......
Old 08-21-2011, 10:35 AM
Z27LS3's Avatar
Z27LS3 Z27LS3 is offline
ignition switch lost power out purple terminal
i just checked the neutral safety switch - no power either side when trying to start engine. no power out purple ignition switch on column, but have power in. switch is new today. seems adjusted ok. i believe a ground is my issue but have no ideas where to start looking. this whole thing started when replacing my tilt column. it was ok before but i am afraid may have had wiring issues band-aided under the dash.
should'nt it be simple with the steering column ignition switch? power in, switch on, power out?
