Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 camaro ignition switch loses power, pics.......
Old 08-21-2011, 02:20 PM
Gringo Gringo is offline
Tell me more about these columns. Are you switching an auto trans column for a standard shift one or just another auto one or to a tilt one? You should have power in, probably a red one. When key is turned on you have power to coil,radio, heater etc ,fuse block. So you should have power out from at least one or more terminals. When turned to start you should have power coming out of purple wire going to one side of safety switch. When safety switch is closed power goes thru purple wire to start side of starter. If you have a tilt wheel, try moving up or down when trying to start. Sometimes these don't make connection when tilted.
