Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 camaro ignition switch loses power, pics.......
Old 08-21-2011, 05:33 PM
Z27LS3's Avatar
Z27LS3 Z27LS3 is offline
the NSS on mine is AT style on end of steering column near firewall. it is the one off the old column. the issue is the power should be flowing out the ignition switch to the NSS. (right?) I dont have power out the purple wire at ignition switch on column. I believe that is where it starts. I understand that switch to have red wire power in (and it is hot), brown is acc power (that is hot) and purple power out when linkage pulls switch up to the start position.
then the NSS gets its power. I have had issues and replaced that last year. I had power in but not out. I also know there is no clutch switch on this car.
I just cant figure out how a new ignition switch can have power in and out but not fire the purple wire to the starter, its adjusted.
any ideas are appreciated, im at a total loss
