Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 camaro ignition switch loses power, pics.......
Old 08-23-2011, 08:31 PM
freethinker52 freethinker52 is offline
that switch is adjustable. loosen the screws and slide it upward. if that doesnt work there might be a problem with the actuator length. take the switch screws out and see if you can get it to work by moving it toward the wheel as you turn the key.
