Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 camaro ignition switch schematic
Old 04-10-2006, 07:44 PM
mvara71 mvara71 is offline
Thank you sir , I was contemplating in getting another ignition switch , tracing the wire is not the problem, is where to connect then on the ignition switch , I remember five wires came out 1 a heavy red, 2 a brown wire, 3 some green wire the goes to the ballast resistor, 4 a purple wire, 5 some green wire that looks like is been used for the gen light went you flip the key , this ignition switch dont have any marking so is hard to tell where to connet this wires.
