69 Camaro kick panel install help needed... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2008, 02:26 PM
Getting ready to install the pass side kick panel and was wondering if there is any tricks I need to know or special info that is helpful?
Old 03-16-2008, 04:27 PM
68firebird
By kick panel you mean the removable plastic panel by the toe board with the vent in it? If so make sure you get the boot part on the back started in the hole then kinda push back and in so the part that sticks up by the dash goes on the flange. Start on the pass side its easier...driver side you need to remove the e-brake.
Old 03-17-2008, 12:17 PM
thanks...
Yep, thats the piece. That tip is very helpful. Thank you!
one piece fiberglass front end for 69 camaro??? chevyelc81 Hotrodding Basics 8 05-10-2011 12:39 AM
Metalshaping/Body Panel Fabrication Randy Ferguson Body - Exterior 15 06-07-2005 12:01 AM
'36 P/U, 69 Camaro subrame engine help!!! Apathy93Z Engine 1 12-08-2004 07:54 AM
Kick Panel Speaker Install 70chevy Interior 3 03-09-2004 06:20 AM
69' Camaro quater panel josh7681 Body - Exterior 6 12-31-2002 02:14 PM
