69 Camaro partial paint pics - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2013, 04:40 PM
Here are a few photos of this camaro that is underway. Shell just about ready to shoot and some parts already sprayed. Lesonal basecoat, SPI universal clear. More photos to come.....
ID:	86945   Click image for larger version
ID:	86953   Click image for larger version
ID:	86961   Click image for larger version
ID:	86969   Click image for larger version
Old 10-06-2013, 04:47 PM
Faith - Respect - Trust
Very nice Dennis, very nice...and that white does pop. I like that your painting it in pieces, always makes for a better job....Good stuff Dennis, keep the pictures coming.
Ray
Old 10-06-2013, 04:56 PM
Thanks Ray, I did the bodywork on the nose and doors the way we discused about the fine grits. The shell was already in spray poly at that point. Took today off, have been averaging 16 to 18 hour days trying to get through all this work. Have never been this busy.
Old 10-06-2013, 05:01 PM
That's great Dennis, let me know how that works for you on the nose and the doors...I'm confident...LOL. It's great to be busy, but those are killer hours, and yes I do speak from experience...just pace yourself my friend.
Ray
Old 10-06-2013, 05:03 PM
Oh, did the finer grits take a lot longer than the coarse grits or was it just a little more time as we discussed.
Ray
Old 10-06-2013, 07:48 PM
Have to be honest, I hated it at first but the more I did, I did get used to it. Overall I think it is not too much longer time wise, because once your ready for primer it is just about done anyway. You will use more sandpaper, for sure but the outcome should be well worth it. Thanks again for the help.
Old 10-06-2013, 09:03 PM
Always happy to lend a hand, I know that it feels like it takes longer the first couple of times...but trust me on this one Dennis, the end results will be worth it...the true test is coming on the final finish...and that is where I'm confident.
Ray
After I posted, I remembered another situation a few years ago where the same problem was happening...The person that asked me why, fought me tooth and nail after I gave him my opinion and he had all the logical reasons why what I suggested wouldn't work...he tried it, hated it...but 6 months later, he was a pretty happy guy...as I said Dennis, I'm confident.
Old 10-06-2013, 09:10 PM
Last journal entry: New Rev wheels and BFG KDW II tires
Could I ask what might be a dumb question? How do you get all the panels to match when you paint them separately?
I thought it was near impossible to do unless they were all hanging on the car and painted at the same time.
The car is looking great btw!
Old 10-06-2013, 09:29 PM
It is most definitely NOT impossible...it's a matter of painting each piece exactly the same as the others. It isn't easy but, it can be done. Here is a picture of tri coat C10 truck I did a few years ago. The base color is blue with a transparent Orange over top of the blue. 1,308 pieces painted separately and then put together...the color is great. The hood was loosely laid on the fenders to line up the flames, removed and the transparent mid coat applied... inner fenders, firewall, rad support, a ton of under hood brackets, tailgate, box, tonneau cover, dash, inside the doors...the list go on...and more small pieces than you could imagine...painted separately and as I mentioned, put together.
Also, 6 months later I was asked to paint a tonnuea cover with the identical flames on the cover as where on the hood...except larger. I keep notes on everything I do. The flames required 7 different different formulas of blue, airbrushed and blended...again, I keep very extensive notes and records...I record air pressure, temperatures and reducers and hardners used to name a few things.
It is very possible.
The third picture is just to show the detail in the chris crossing and blending of the flames that needed to be matched 6 months later.
Ray
Name:	Blue Base with ghost flames.jpg
ID:	87241   Click image for larger version
Name:	hood before polishing.jpg
ID:	87249   Click image for larger version
Name:	Flames close up crossing.jpg
ID:	87257   Click image for larger version
Name:	Detail before Lake George.jpg
Old 10-06-2013, 09:41 PM
Not a dumb question at all. Keeping every little detail exactly the same when spraying. Gun setting, air pressure, painting panels just how they will appear on the car (doors not laying down) but sprayed in the same position that they would be on the car. Painting completely past each panel getting full coverage on the ends. This one I had to have more color mixed after I had painted quite a few parts. So I am saving the remainder of color in my original gallon as the last coat over the new mixed color just in case. But if your new at this with a mettallic color I would reccomend painting the car assembled, so as not to have any color variations as this would be a very costly redo. This color is around $535 per gallon times 2 gallons, plus reducer and 2 gallons of clear. Not a cheap ordeal, and would want to have to spend all that money all over again. Let alone all that labor...
Old 10-06-2013, 09:45 PM
Come on Ray keep those pics coming.........I know you do have more!! Beutiful job bye the way, lets keep it going.
Old 10-06-2013, 09:47 PM
Ray
nice truck ray good job
Old 10-06-2013, 10:05 PM
LOL...guys I do have a boat load of pictures, they are on a computer that I was using a while back and I upgraded...in the last 2 months I've been trying to get them off of that hard drive onto the one I have now...I am a computer techtard...LOL...I have hired several other guys to lend a hand...with no luck...yet, but, I have spent a fair amount of money from paying the guys that have then knowledge to replacing hardware on my shop computer (that's the faster one) and still haven't been able to retrieve them. This all started when I wanted to show another member some custom work on a dash and interior I did on 67 Nova. The Nova had a custom built full console from dash to package tray, with DVD player in the dash, all switches, lights, ignition, accessory plug, wipers, power windows and locks and a bunch more was moved to the console. Those pictures are on the hard drive that I can't access...I'll keep trying...I just need to save more money...the last run cost, well several dollars...LOL
I'll get it done though and post pictures.
Here's a 68 Firebird done in PPG tri coat Vibrance...the color is called tiger eye. This again was painted in pieces, even the engine block, transmission and drive shaft are all body color.
The other picture is of the engine compartment of the C10, also the engine and transmission where painted body color, I wish that this one showed more detail with respect to paint under the hood. It was taken more to show the 502 with a turbo than anything else.
Ray
Name:	68 Firebird 1A.jpg
ID:	87273   Click image for larger version
Name:	engine compartment.jpg
Old 10-07-2013, 12:02 PM
67Elcamino's Avatar
Im currently painting a car myself in pieces. I hate spraying on a horizontal surface as I always seems to get tigerstripes.. Its a convertible but was planning on shooting the hood laying vertically. Is this a No no?
I heard you say to shoot them in the same position as it would be on the car. Whats the reason? metallic flake laying at different angle?
Old 10-07-2013, 12:12 PM
Yes that is exactly right. Shooting a hood laying flat would be much easier, and that is how it would appear on the car any way. I have got away with spraying doors laying down in the past, but now I hang the whole door in the position it would be on the car and is much easier to shoot the inner jamb all at once (no back masking) can get nice wet edges all around.
The ultimate budget paint job thread /w pics (rustoleum paint) Project89 Hotrodding Basics 130 04-24-2012 12:19 AM
Paint day! 68 camaro (pics) shoddy_f-body Body - Exterior 29 10-16-2011 01:14 AM
98 camaro carb'd pics falconsfan Engine 2 06-25-2011 07:46 AM
70 camaro needs needs new pans, some pics Gladis Body - Exterior 9 03-29-2007 02:01 PM
My Camaro pics bigblock454camaro Introduce Yourself 2 09-04-2006 08:15 AM
