Thread Tools Search this Thread share on Facebook
  #1
Old 08-28-2010, 09:46 PM
69Bowtie's Avatar
69Bowtie 69Bowtie is offline
69 camaro quarter louvers
I just bought a pair of these to install. There are two studs on top and bottom. Are you supposed to drill small holes and press these in? I'm going to purchase a template to line them up but I'm not sure the proper way to install these.
Register now (free) or login to remove ads
Old 08-28-2010, 10:00 PM
alittle1 alittle1 is offline
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
You should use a bezel nut that screws on to the stud from the chrome louver, you have to go inside the rear seat panel to get at it. Just sliding through the hole just won't do it. Try your local GM dealer's parts department or body shop, bring the part with you and they should be able to give you the correct nut to fit it.
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
You need "barrel clips" pushed onto the studs if you just want a push-in installation. Originals were held on with self threading panel nuts from the inside.
Yes, they just fit into drilled holes.
EDIT: Be aware you may have to bend the ornament, some of the repros I have seen are too flat and don't fit the curve of the quarter well at all.
Old 08-29-2010, 07:47 AM
69Bowtie's Avatar
Thanks, appreciate the help.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "69 camaro quarter louvers"
ThreadThread StarterForumRepliesLast Post
one piece fiberglass front end for 69 camaro???chevyelc81Hotrodding Basics805-09-2011 11:39 PM
The first 69 Camaro built for competitive driftingChevelleSS_LS6Hotrodders' Lounge2011-16-2005 06:43 PM
'36 P/U, 69 Camaro subrame engine help!!!Apathy93ZEngine112-08-2004 06:54 AM
i want too change a 69 firebird intoo a 69 camarotraviss10_999Introduce Yourself107-03-2004 12:17 PM
509 BBC 69 camaro, its all about the engine baby!Quarter mile killerHotrodding Basics1210-28-2003 01:40 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
