Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 Camaro Rear Disc Brake kit??
Old 04-02-2010, 06:00 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
You could try Speedway Motors, they have some low cost kits.
I think you are going to have a problem finding a kit that doesn't move the wheels out farther because of the thickness of the rotor where it fits over the studs on the axle, no way to make this as thin as the drum brake is at that particular spot, but if you had a 1/4" to work with you might find some to fit that have a steel drive "hat" with a seperate rotor that bolts to the hat.
Check for low cost circle track kits too, but these won't have the E-brake provision.
