69 Camaro Rear Disc Brake kit?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2010, 04:54 PM
Hello, Can anyone give me some good advice on Putting a Rear Disc Brake Kit on my Camaro. Currenly I have Drums on the back and factory Discs on the front. I would rather not spend the money on Wilwood because I do not race this car and don't need that High Tech of Brake, however I want something that will still look good at a reasonable price. I Would like the Drilled Rotors becasue you can see them due to the wheels I have and want them to look good.
I currently have 17" American Racing Torque Thrust 11 wheels on the back and they set perfectly. I need a kit that will directly replace the drums without spacing the wheels any differently. The backspacing on these wheels took 4 sets to get them to fit perfectly.
Anything you recommend?
Thanks a bunch in advance
Ben
Old 04-02-2010, 06:00 PM
ericnova72's Avatar
More for Less Racer
You could try Speedway Motors, they have some low cost kits.
I think you are going to have a problem finding a kit that doesn't move the wheels out farther because of the thickness of the rotor where it fits over the studs on the axle, no way to make this as thin as the drum brake is at that particular spot, but if you had a 1/4" to work with you might find some to fit that have a steel drive "hat" with a seperate rotor that bolts to the hat.
Check for low cost circle track kits too, but these won't have the E-brake provision.
Old 04-02-2010, 06:43 PM
Wiki Edits: 27
rear disc s
I think some rear disc's from front drive caddy. buicks are an easy swap and they have e brakes I pulled some a while back when my buddy was crushing cars. I think on some gm axles you have to turn down the shaft so the rotor will fit on and use longer studs.
Help with 68 camaro emergency brake install disc brake jdp2603 Suspension - Brakes - Steering 4 02-13-2010 07:56 AM
Where can I fnd a disc brake kit for jaguar rear end Larry Tyner Suspension - Brakes - Steering 8 01-08-2010 01:50 PM
95-01 Explorer rear disc brake questions baddbob Suspension - Brakes - Steering 9 02-10-2005 09:19 PM
granada disc brake rear end infro Bad Rat Suspension - Brakes - Steering 8 02-28-2004 02:21 AM
Disc brake kit? Bo_Jangles Suspension - Brakes - Steering 0 06-25-2003 06:22 PM
