69 camaro steering wheel installation - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2007, 04:12 PM
I've got a 69 RS Camaro that I'm attempting to put the original plastic steering wheel on but the steering shaft isn't long enough for me to install the steering wheel. What am I doing wrong? Funny thing is that I'm the one who took the old steering wheel off several weeks ago to fix an ignition switch problem. Thanks for any help
Brads1966
Old 12-26-2007, 05:14 PM
Last journal entry: frame build
If the shaft doesn't stick out of the housing far enough, you have managed to push the shaft hard enough to slide it in the collapsible section.It can be pulled back up with the tool used to push the lock plate. I don't remember if the 69s had a lock plate but it will still work. It gives you something to pull with. Technically, the column should be replaced, but realistically, there are alot of them being used every day that have been collapsed and pulled back out. This is for the doubleD shafts not the mesh ones.
1969 Camaro Shifter And Trans Installation Help JimKramer Transmission - Rearend 2 05-01-2006 08:14 AM
Will power steering box from 82 camaro work in 67 el camino dave2148 Suspension - Brakes - Steering 7 09-05-2005 09:37 PM
Putting on new air bag steering wheel on a older steering collumn. CruisingRam Interior 10 12-20-2004 04:34 AM
'36 P/U, 69 Camaro subrame engine help!!! Apathy93Z Engine 1 12-08-2004 07:54 AM
69 Camaro, power steering? FiefSS Suspension - Brakes - Steering 1 01-03-2003 01:30 PM
