69 Chev 350 block has a distributor bushing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2007, 05:37 AM
I pulled the top half off of an Impala 69 chev 350 and when the distributor came up it pulled a bushing out of the block. I've never seen anything like this. The bushing was stuck to the distributor and won't pass through the intake manifold. I was hoping to salvage all the parts especially the block but now am wondering if the bushing will go in straight. Has anyone else seen a chev smallblock with a bushing like this? I'm thinking GM had maybe a bad production run on some blocks and used a bushing to correct some alignment problems?
Old 06-22-2007, 04:22 PM
CNC Blocks Northeast
The blocks I have seen with the bushings in them have had a tack weld on the bottom side.
Bought 350 block and came with free heads('62 327 75cc????) 89SDime Engine 7 01-14-2006 05:50 PM
Is there a 350 Big Block? AMDAP Engine 16 12-21-2005 05:10 AM
small block into 52 chev sedan neil francis Suspension - Brakes - Steering 1 10-02-2005 08:20 AM
350 SBC: '70 top end on '90 block? Arcuden Engine 7 09-09-2005 12:49 AM
Installing a chev small block in the rear of an chev s-10 vegadeth Body - Exterior 11 07-16-2002 03:16 PM
