69 Chevelle boxed control arms/sway bar - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2005, 04:43 PM
ss396si's Avatar
hello everyone,
im gettin boxed lower control arms for my 10 bolt rear. Do i have to use a torque wrench to tighten the bolts?
Do i have to torque the uppers as well?
thank you
Old 02-16-2005, 05:38 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Torque wrench
Owning and using said implement is always a good Idea..saves a lot of broken bolts..
OMT
Old 02-19-2005, 07:39 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Both ends of both the upper AND lower control arms (ALL 8 bolts) should be torqued to 70 foot pounds of torque.
This is according to both manuals I have here and specs on another website I am a member of.
Old 02-19-2005, 05:37 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
boxed bars
Not if you don't loosen them. You do not have to loosen them to install the lower bars. If you are buying SSM lift bars you will need to set the pinion angle. I would suggest you change the upper bushings to neoprene. It will make the lower bars work much better.
Malibu racing by any chance?
