69 Chevelle Charging Issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2010, 04:59 PM
I have a 69 Chevelle and the alternator is not charging. Im getting 12.5 at the battery and 12.1 when the lights are on. I have the alternator with the 4 wires on the back with and external regulator. If I put my voltmeter on the lug marked BAT and the lug Marked GRD I get about 20.5-21.0 volts. I replaced the voltage regulator and also had the alternator tested. The test said the alternator was fine. I have a painless wiring system on my chevelle. Any help would be greatly appreciated. Thanks.
Old 11-08-2010, 10:30 AM
kd5icr's Avatar
Camaro Guy All The Way!
I would convert to a different alt. this makes fixing any problem a snap.
It would look Something like this.
Old 11-08-2010, 04:26 PM
I just replaced the alternator and still having the same issue. I checked the grounds and everything looks good. Is there anyone in this forum that knows anything about this this system. The only reponse I have gotten is to change it over and I don't want to do that. Thanks.
Old 11-08-2010, 04:52 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Check the wires at the regulator could be a loose connection or a broken wire. Have you done a run down on all the wires yet? JMO
I have had this happen to me before also i changed the regulator and while doing so i found a connection bad and replaced the harness fron the fire wall out fixed my problem. JMO
Cole
Old 11-08-2010, 04:57 PM
Its like the regulator isn't giving the signal for the alternator to charge, Ill open up the harness cover tommorrow. It's all new painless wiring system so the wires should be fine. Should I trace all the regulator wires.
Old 11-08-2010, 04:59 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Have you replaced the voltage regulator??
There is a solid state version available that (I hear) is much more stable than
the OEM regulator
Old 11-08-2010, 05:01 PM
Replaced it twice just in case had gotten a bad one.
Old 11-08-2010, 05:06 PM
kd5icr's Avatar
Something else to try would be to call painless and see if anybody else has had this problem. And all I said earlier was what I would do. you took it wrong. Haveing said that maybe there was a snafu that painless had with that harness and they may have a solution for you or can tell you were to look for a problem, they made it after all. Thats just my thinking.
Old 11-08-2010, 05:23 PM
eloc431962's Avatar
Wiki Edits: 37
the OEM regulator
X2 On this (solid state version ) much better.
Cole
Old 11-08-2010, 06:06 PM
I have a VR715 voltage regulator in it. Is that a solid state one.
Old 11-08-2010, 06:11 PM
eloc431962's Avatar
Wiki Edits: 37
Yes that's it .
Cole
Old 11-08-2010, 06:17 PM
Ill probably know more tommorrow when I check the harness. I have spent about 7 hours on this and I am pulling my hair out. lol.
Old 11-08-2010, 06:20 PM
eloc431962's Avatar
Wiki Edits: 37
Yep time to take a break.
Cole
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
69 Chevelle lg1969 Hotrodders' Lounge 0 04-15-2009 01:51 PM
Vinyl top removal, 69' Chevelle the donk Body - Exterior 3 11-11-2008 11:06 AM
matching number car 69 chevelle SS hotrod98 General Rodding Tech 3 04-11-2007 06:31 AM
69 Chevelle radio DougMN Electrical 3 12-23-2006 09:25 PM
