69 Chevelle distributor problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2009, 02:17 PM
im working on a 69 chevelle SS 396 its the post type is this the chevelle 300 the problem im having is the points when i hook the wire from points to the wire from the coil it grouds out and the wire becomes dead what am i doing wrong the wires from switch i got going to the + side and the wire from the - side to the points is this right
Old 09-30-2009, 02:42 PM
wretched ratchet's Avatar
one full turn after it squeeks
Hey, Boone, Welcome - - if you will post this question in the Engine Thread, you will probably get more viewers - - not every member checks the Introduction Thread. Good Luck !
Old 09-30-2009, 02:46 PM
poncho62's Avatar
Wiki Edits: 5
Moving this to electrical.......Probably have a short in the distributer.
Old 09-30-2009, 06:41 PM
T-bucket23's Avatar
Wiki Edits: 26
Originally Posted by boone44
im working on a 69 chevelle SS 396 its the post type is this the chevelle 300 the problem im having is the points when i hook the wire from points to the wire from the coil it grounds out and the wire becomes dead what am i doing wrong the wires from switch i got going to the + side and the wire from the - side to the points is this right
If the points are closed it is supposed to ground that wire. I have a wiki article on troubleshooting ignition issues. If you go step by step you will find your issue. Did you gap the points, did you try to start the car?
Wiki Article
Chet
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
69 Chevelle lg1969 Hotrodders' Lounge 0 04-15-2009 01:51 PM
'69 Chevelle Rearend number lt1_performance Transmission - Rearend 1 04-27-2008 01:00 AM
Will a 69 Chevelle rearend fit my '67 Chevelle lt1_performance Transmission - Rearend 2 04-26-2008 10:10 PM
will a '69 Chevelle rear end fit into a '70 Chevelle? SMO'KUM UP Introduce Yourself 2 09-17-2007 07:15 AM
