69 chevelle driveshaft... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2003, 08:30 PM
New Member
hi all,, i have an 69 chevelle that i am restoring, when i got it it had no axle nor driveshaft, i found the axle and mounting it, however, i need to know what is the measurement of the driveshat since i have one that i pulled out of another malibu el camino year 77, i beleive that one is a bit too long so i need to find out what the exact measurement of the original one were.... i performed a search for driveshaft on this site but couldnt find anything about that car and year in particular,, i also searched on google to no avail,, any help would be deeply appreciated,, tnx in advance...
Old 06-20-2003, 08:44 PM
go to dennysdrivshaft.com
there is a page on how to measure to have a shaft made. they made one for my 67 firebird. the fit was excellent
Old 06-20-2003, 08:49 PM
More information is needed.
The type of transmission you have helps determine the lenght of the driveshaft.
Also 2 door or 4 door (wheelbases are different)
A easy way to do this if you have the correct slip yoke is to put the yoke in the transmission, push it ALL the way in and pull it out 3/4 inch. Then measure the distance between the cross centerline and the rear end yoke centerline.
Also most used yokes will have a wear ring worn into the yoke. This is where the factory had the yoke (in/out) riding. Always a good guideline.
