69 chevelle headliner removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2005, 08:12 PM
I am attempting to remove a brand new, perfect headliner from my car and not sure how to get it loose after I get the ''U'' shaped piece off.It is tucked over some sort of '' tack strip'' or something. Help. P.S. I am doing a frame off on this car and it already had a new headliner in it.
Old 08-13-2005, 06:42 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
ine never removed a good one but that is about right its like a peice of tack strip i would fo to u pull it and try some experiments 1st i would think a little reverse pressuer would release it
good luck im curiouse about how you make out
SR66
"SlowRide66"
"Illegitimis non carborundum"
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
posi for a 69 chevelle 66GTOguy Introduce Yourself 0 09-09-2004 02:42 PM
HEI upgrade on 69' chevelle 307 malibuman Engine 3 10-19-2003 01:31 AM
69 chevelle disc brakes 87 350monteSS Suspension - Brakes - Steering 4 07-17-2003 07:33 PM
Best place to order patch pannels for 69 Chevelle? zachscc Body - Exterior 8 01-02-2003 05:44 PM
