'69 Chevelle Rearend number - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2008, 03:11 PM
Last journal entry: more...
I bought a rear end for my chevelle recently. I absolutely cannot find the numbers on the pass. axle tube. Actually, I cant find any numbers on the rearend that I found were supposed to be on a chevelle rearend. (not even a date code) I can tell it's an 8.2 rearend by the cover and the suspension brackets look to be setup for my chevelle. What are the exact locations each individual number is supposed to be in. Thanks
*edit* I took a wire brush out there with me and scratched around on the axle tubes and found some numbers. "A C K 006" Anyone know what these mean?
Old 04-27-2008, 01:00 AM
RODDER18's Avatar
Use a grinder with a wire brush attachment this should clean it up enough to locate the numbers. They should be on the top of the passenger side tube.
Name:	REAR DIFF PICS.jpg
just found a new 327 out of a 67 SS chevelle motor number 3858180 Mr. Wormy Engine 2 02-04-2006 08:02 PM
'69 chevelle ss 68sleeper Hotrodders' Lounge 0 10-13-2005 08:43 PM
69 Chevelle Mirror Image Body - Exterior 0 06-04-2003 07:54 PM
Best place to order patch pannels for 69 Chevelle? zachscc Body - Exterior 8 01-02-2003 05:44 PM
69 Camaro rearend Bowtie1034 Transmission - Rearend 0 11-02-2002 02:52 PM
