Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 Chevelle rocker panel removal
  #25 (permalink)
Old 01-04-2013, 09:43 AM
tech69 tech69 is offline
put up or shut up
as DB stated, don't be afraid to mock it up a bunch of times and looking closely each time at what you need to do when you take it back off, it's normal even for the pros. noticing the small stuff and dealing with it and re-mocking can be the difference between the panels lining up perfectly and having to tweak the flange just to get a flush fit for plug welds. So with that said, a lot of emphasis on mating flanges that get plug welds.
