Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 Chevelle rocker panel removal
  #57 (permalink)
Old 02-15-2013, 09:05 PM
Wrencher's Avatar
Wrencher Wrencher is offline
I have run into a small problem! I'm putting the floor back in, rockers are in, lined up nice at the quarter and inner wheelhouse bottom, nice in the pillar skirt, braces are in....it seems the left and right front floor mounts at the toeboards are about 1/2 inch too high? or my floor is too low? I removed the floor bushings thinking that might help, actually the bushings don't affect the floor height at all. I'm not sure if something moved, the mounts line up, I did cut out the kickpanel area to replace the innerds. Not sure what I'm missing, drivers door sags about 1/4 inch, yet is perfect when closed, haven't mounted the pass yet. I know it's tough without seeing it, any hints on what to line up first or work from? Thx
