I dont mean to scare you off but have you looked at the other side yet
Hey that might be the good side...
| The Following User Says Thank You to deadbodyman For This Useful Post: | ||
tech69 (01-02-2013) | ||
Thanks DBM, it's gettin both sides, there's rust holes in the other one also, and I know the inside is rustville. I've got sawzalls, bodysaws, I'm waiting on the floor panels before I cut them out, I got the 4pc panels, and I'm not sure the rocker lip comes with em? Is that usually the case? If so I'll start
One rule I have (for many reasons) is : never cut or take something apart untill you have the parts sittin there...
when you get the parts assemble them on the floor to see how everything fits and get familar with the assembly.... insted of cutting everything all at once what you should do is remove the rockers outer skin ONLY and using drill screws fasten the new one to the old steel getting good door gaps before going any further..Once thats screwedunscrew the new outer rocker and set it aside in then remove the inner rocker and screw the new one in and both together (only enough screws to hold it in place) These screw holes will be a big help in relocating the pieces in the exact spot every time... The floor pans should have a lip that welds to the inner rocker you'll have to drill or punch holes in that lip where you want to weld ,every 2" or so... when you get to the floor pan getting that lip to seat against the inner rocker can be a challenge at times what you want to do is line up grooves in the new pan with the old floor and worry about the floor to rocker fit later.screw the new pan to the old floor,(trim it down later) if the fit to the rocker has a gap you may have to flatten the lip and make a new lip in the right spot , but dont worry about that right now thats a pretty ez fix... Just start on the outside and work your way in ,one layer at a time replacing each layer as you go and remove that layer to get to the next one using the screw holes as your guide... You may have to take this thing apart and put it all back together 50 times before your ready to weld but before you weld anything be sure everywhere you need to weld is clean to the metal and both pieces are tight together or you'll have burn outs and ugly everywhere...Take your time.... I'll be going to the salvage yard this weekend to get my rocker section I'll take a vid.. Last edited by deadbodyman; 01-04-2013 at 07:09 AM. |
Wrencher (01-04-2013) | ||
| The Following User Says Thank You to tech69 For This Useful Post: | ||
as DB stated, don't be afraid to mock it up a bunch of times and looking closely each time at what you need to do when you take it back off, it's normal even for the pros. noticing the small stuff and dealing with it and re-mocking can be the difference between the panels lining up perfectly and having to tweak the flange just to get a flush fit for plug welds. So with that said, a lot of emphasis on mating flanges that get plug welds.
For us ,the inside is just as important as the outside just because nobody will see it dont mean you can get slack with your work...
the least important would be if one mating flange hangs over the other. as long as it's mating and you have it nice and flush with floor/outer rocker with a decent amount of mating surface for a plug weld it's common to shave a little off if it looks funky.it's all important cause kicking the can down the road can mean ugly welds that you have clean up.
I will put her back together correctly! I"ve got some rot at the frt inner rocker, under the pillar, and the lower cowl, and am currently peeling up the floor. I got the 4pc floor, shoulda got the 2pc, but, oh well. I will post pics, haven't had much time lately.
I got my used rocker section yesterday ...hopefully I'll start drilling and seperating the pieces today...
If the inner is in pretty good shape it may be easier to replace just the rotted section... |
| 71 chevelle inner rocker panel replacement | race_jr | Body - Exterior | 0 | 07-04-2011 10:57 AM |
| Quarter panel to rocker. | price | Body - Exterior | 2 | 03-08-2011 11:42 PM |
| rocker removal | adrock430 | Body - Exterior | 2 | 02-08-2005 06:42 PM |
| Rocker Panel Replacement | johnnymopar | Body - Exterior | 2 | 05-17-2004 11:05 AM |
| Rocker Panel replacement ? | bowtieorbust | Body - Exterior | 2 | 09-08-2003 10:07 AM |
