69 Chevelle rocker panel removal - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 02-23-2013, 09:06 AM
deadbodyman's Avatar
Wiki Edits: 11
The door issue should be addressed first before going any farther ...are you sure you cant wiggle the doors up and down? it would make sence because if the doors are low then move up to latch over the striker something is allowing the door to move up and that would be the pins and bushings...Other wise the door would stop dead when it hit the striker and not be able to close if the hinges were were right...Those ae some heavy doors so try lifting them up from the back and put some muscle in it...
You dont need any bracing to do the trunk floors...but you should get started with welding the rockers and floors a bit before starting the trunk...
  #62 (permalink)
Old 02-23-2013, 02:38 PM
Wrencher's Avatar
No, definately not hinges, the quarters are loose at the stricker a tad, and the pillars are screwed also, which could let it latch. At first glance it seems the frt quarters need to drop, or the A pillars need to cantilever, I've tried moving the pillars, that just gives me fore and aft movement...no tilt.
I also noticed my rockers are not straight from frt to back, there's a slight bow outward....shouldn't they be straight as an arrow along the lower door and quarter skirt? I'm not sure if they came that way, or if jacking it up caused it...yes they were screwed top and bottom before I jacked it up.
Also, I'm doing the whole trunk floor, braces and all...support is on the rear braces?
  #63 (permalink)
Old 02-23-2013, 06:47 PM
Wiki Edits: 11
are your door jambs still braced? show a pic of how you did them I'm a little confused....I have to go back and read from the begining but I thought the door gaps were fine before you started ....I tell ya what...take the striker out and slowly close the door lets see what happens then but first scribe a line around the the striker shims so you can put it back in exactly the same spot later or use the scribed line as a reference...we may have to get together with a phone call....
  #64 (permalink)
Old 02-23-2013, 08:33 PM
Wrencher's Avatar
I had them X'd in the jamb area before and removed them after I had the floor and rockers screwed and tacked. They weren't behind the jamb...in it. Yes gap was good originally...I know this is a looong post, These are not off alot, 1/4 inch at most, maybe it's normal for all the crap I've replaced?? I appreciate the help, but this may be one I have to find alone if you know what I mean LOL. Will an assembly manual give me any measurements to use?
  #65 (permalink)
Old 02-24-2013, 06:47 AM
Wiki Edits: 11
The measurements wont be in an assembly book but a book will come in handy for a lot of other stuff later on and the frame measurements will only confuse you more any way.....
We'll figure this out EZ enough...First pull the striker out and see how the door acts when you close it and the gaps will tell you everything you need to know...Take some pics, lots of them ,they'll help immensely...
As far a the leangth of the post goes dont worry too much about it ,all the problems you are having are normal for a DIY so it can only help anyone readingthis and similar work...
You want to skip over this and move on to the trunk floor then come back to it later ,dont you??? LOL ,be patient, thats one of the important things to learn...
  #66 (permalink)
Old 02-24-2013, 07:09 AM
Wrencher's Avatar
Yes, it's taking alot of time on these gaps, and I'm not sure if it's NORMAL for this, or structural? I can control the frt to back gap with the pillar location, although it changes my rocker fit there. It's the tilt that has me stumped. I have cut out the corner below the quarter window, where the seat floor and quarter support meet for a new piece, but that support is solid, it won't budge. I basically removed every support area from the rear rocker forward, took out rear seat brace, but left the seat floor in, floor and braces, kickpanel to firewall plate. i have the r rocker out and the door fits the same ( rocker is bowed ). I'll get pics and try the striker deal in a hour. Thx
  #67 (permalink)
Old 02-24-2013, 08:51 AM
Wiki Edits: 11
The rocker should be straight or at least the same contour as the door bottom.My only concern is if the door moves up to go over the striker why cant you lift it up by hand? The door IS moving up The 1/4 cant be going down...So taking out the striker will allow the door to close without moving and the gap should be tight at the top and wide at the bottom so what you need to do is with a wooden wedge or a floor jack have someone lift the door while you are watching that front pillar to see whats moving if its the pillar then (i cant see how if it was braced and the pillar is screwed to the rocker) then close the door and use the wedge to lift and hold the door to the proper height and rescrew the front pillar where it sits now.
There can only be two causes for the door to be able to move up if all the bolts are tight ,the hinges or the pillar moving.The bushings in the hinge dont have to be worn much to get a 1/4" of movement at the rear of the door so if theres any play at all this would be the cause.
.the pillar can only move forward because of the weight of the door so if it moved it could have only moved foward. it's also possible to move the pillar back by using a bottle jack against the tire and jacking the pillar back until the door is in the proper positiobut be very careful and it wont take much jacking at all just watch the top gap as your jacking the pillar back.The top of the door and the top of the 1/4 should be the same hieght with a nice even gap of no more than a 1/4" or less all the way down....So theres a few things to try when you get out there... sStart with the striker.just remember the door has to close without any up or down movement,and if its moving it has to be in the hinges or your pillar is loose...(if all the hinge bolts are tight )
The Following User Says Thank You to deadbodyman For This Useful Post:
Wrencher (02-24-2013)
  #68 (permalink)
Old 02-24-2013, 10:56 AM
Wrencher's Avatar
Here are some pics...I keep getting server error, I'll try more
  #69 (permalink)
Old 02-24-2013, 11:03 AM
Wrencher's Avatar
Here is one more, I can only do one at a time??? Now NONE LOL that's the rocker with straight stock taped to it.....bowsville I can't do any more pics, Headed back out, will respond on the movement
  #70 (permalink)
Old 02-24-2013, 03:17 PM
Wrencher's Avatar
DBM, Eureka! It was the combination of the panel I made at the cowl/firewall/ lower fender mount, and lower pillar flexing in and out from the floor not yet welded and the inner cowl and outer panels not in yet. My panel was flexing as it was only straight metal without the factory supports made into it. Thanks a TON for the help.
Now, if I can figure out my rockers are bowed or not....door bottoms are wavy, but straight.
  #71 (permalink)
Old 02-24-2013, 05:29 PM
Wiki Edits: 11
That rocker is definetly bent but it only looks bent at the end to me...Go look at the other side at the original rocker I believe its straight as an arrow...
That first pic told me everything I needed to know ,it's true a pic is worth a thousand words...LOL
Patience is your most important tool ....I knew you'd get it...
  #72 (permalink)
Old 02-24-2013, 06:05 PM
Wrencher's Avatar
Are you talking about the door picture LOL?
Well, I don't have the old ones, cut up anyway.....I know, 1 side at a time, but I had to remove it to fit the floor and braces????
The other repo rocker looks the same, slight bow, I don't know, should be straight, Thx again DBM!
That straightedge isn't flush at the other end either!
  #73 (permalink)
Old 02-25-2013, 06:46 AM
Wiki Edits: 11
Actually You should have finished welding up the first rocker without welding the floor brace that hould have been left in...You even want to cut the floor unle you abolutely have too...once the new rocker i in and fitted That when you want to start cutting out the rotted floor or even better would be to do the other rocker THEN the floor and braces....
It ound like your jut about ready to weld that rocker upso heres a little tip I use all the time
At the bottom of the rocker where thr inner rocker are welded together i called a pinch weld once the inner and outter are intalled with drillscrews and everything is double checked ,gaps are good ,it all needs to come back apartfor welding....I've found its much easier to weld the inner to the outter along the pinch welds while its on a bench theres no need to do it upside down and on the car ,the welds will be better and you can grind and dress up all the welds without doing it on your back ...Just install it as a unit ...heres a pic of what I mean...This is the inner and outter rocker I made for my old coupe...
  #74 (permalink)
Old 02-25-2013, 06:47 AM
Wiki Edits: 11
OOps ,ran outta time ...I'll get back to ya...
  #75 (permalink)
Old 02-25-2013, 07:50 PM
Wrencher's Avatar
Actually thing only thing welded is the floor at the toeboard, and at the rear seat top. Everything else is screwed. 4 pc floor. I pulled one outer rocker back off to replace it, I may try your tip if I can get them both in together.
I put the rockers in and bolted in the frt and rear floor braces because I knew they had to mount precise, screwed the braces to the inners, which is difficult with the bushings in, then the floor.
Hell, I figured it didn't matter how it came apart, I knew there was a method...now I know for sure. That's why it's been such a bear, I wiped out every reference point in site LOL. I even cut out the inner quarter support at the seat pan and replaced that section. I need to start welding the cowl/kickpanel area, but I'm trying to leave the rocker screwed until I fit the new quarters, the wheelhouse edge is gone from rust, so I really don't have a reference point at the rear?
I've watched alot of video's on floor and rocker replacement, but, most of em are either floor pieces, or just outer rocker, or, they cut the floor out and weld the new in. I wanted to replace THE FLOOR, not just cut it out and weld to the old rocker lip.
71 chevelle inner rocker panel replacement race_jr Body - Exterior 0 07-04-2011 10:57 AM
Quarter panel to rocker. price Body - Exterior 2 03-08-2011 11:42 PM
rocker removal adrock430 Body - Exterior 2 02-08-2005 06:42 PM
Rocker Panel Replacement johnnymopar Body - Exterior 2 05-17-2004 11:05 AM
Rocker Panel replacement ? bowtieorbust Body - Exterior 2 09-08-2003 10:07 AM
