69 Chevelle trans swap choices - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2011, 07:14 AM
I've been lazy on a customer's 69 Chevelle and need to get back to it. It's a 350 model with a 2 speed. I never checked to see which one or what the options of 2 speeds there are which is shameful with my background, but I've been lazy... It's burned up and will be replaced with either a TH350 or 400. Which is the better choice considering ease of swapping (driveshaft cutting/slip yoke, rear mount locating, linkage)? He brought me a 350 from a 4 wheel drive but that's just *** backwards to convert it to me. I'd rather start with the right one and build it from there. This will be strictly a cruiser/second childhood with NO performance intentions. Yep, boring. Maybe that's why I can't stay focused...
Old 07-01-2011, 10:15 PM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
I believe that tranny would work but you'd have to change the final drive shaft in the tranny and put a tail shaft housing on the case. I think the yolk and drive shaft off the power glide would work. Don't quote me though, check with a tranny shop for sure.
Old 07-01-2011, 10:27 PM
prostreet6t9's Avatar
Differential/Driveline
If your PG has a fine spline output shaft your slip yoke will work. The 350 will be a easy swap.
Trans choices...72 Monte Carlo Crow44 Transmission - Rearend 11 06-02-2009 08:30 PM
3spd trans. for 72 chevelle ss steven linker Hotrodding Basics 9 05-18-2006 11:35 PM
will a power stering box from 83 trans am fit 68 chevelle 4onthefloor 2 Suspension - Brakes - Steering 4 02-13-2005 10:52 PM
manual trans in my chevelle.... dk01_99 Transmission - Rearend 5 02-15-2003 11:27 AM
Hemi update and choices, choices! HemmiGremmie Hotrodders' Lounge 3 09-07-2002 08:54 PM
