69 Chevelle upper control arm - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2009, 12:35 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Hi, ever since I raised the front end with heavy duty springs to clear the headers and a deep sump tranny oil pan the upper ball joint is wearing prematurelly. The upper control arm is angle so high the Ball joint is not centered. It's angled. Can any body help me?
Thanks
Louis
Old 08-20-2009, 06:57 PM
RODDER18's Avatar
You could use a ball joint spacer but new control arms would be the ultimate answer. Check this site.
http://scandc.com/
Old 09-11-2009, 08:42 PM
ema ema is offline
New Member
Rodder18 is correct. Replacing the control arm would be the best solution for that. A ball joint spacer should also do good but to achieve full solution, just go with the whole control arm instead.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
69 Chevelle lg1969 Hotrodders' Lounge 0 04-15-2009 01:51 PM
replacing control arm and body bushings elcaminodragster Suspension - Brakes - Steering 10 09-01-2008 06:07 PM
Will a 69 Chevelle rearend fit my '67 Chevelle lt1_performance Transmission - Rearend 2 04-26-2008 10:10 PM
Control Arm Bushings clouddancer@attbi.com Suspension - Brakes - Steering 4 10-04-2002 07:26 AM
