69 cheverolet c10 what could be use a doner veichal for disc brakes?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2011, 05:16 PM
anyone know what yr of chev that i can use the front disc to make my 69 c10 from drum to disc brakes without buying a kit?? thx!!
Old 06-25-2011, 05:20 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site if you post your question in the proper section someone will come along to help you out. http://www.hotrodders.com/forum/susp...akes-steering/ . Not everyone checks the intro section.
Cole
Old 06-27-2011, 08:52 AM
73-87 C10...... you will need the spindles, new ball joints and tie rod ends for the 73+ and it is a direct swap.....
Old 07-01-2011, 11:02 AM
1971BB427's Avatar
'71-72 will bolt right on and you'll have 5 on 5 bolt pattern. Should then change the rear axle shaftts to later 5 on 5 axles too and match them. My '69 C10 Suburban got this swap all around, along with HD swaybars, and she stops and corners like a new truck.
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 09:38 AM
anyone have more info about Studebaker bodies & Cheverolet/GMC S-10 and S-15 frames? ret_marine2003 Hotrodding Basics 9 08-20-2008 10:22 PM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 02:07 PM
Weight of Disc Brakes vs Drum Brakes leejoy Suspension - Brakes - Steering 7 06-29-2007 12:41 AM
disc brakes knuckles Suspension - Brakes - Steering 2 03-20-2005 08:11 AM
