69 chevy break fluid leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2007, 07:27 PM
have a fluid leak between the break fluid reservoir and the power break booster, can someone tell me what kind of seal or gasket do i need to change and what is involved. tomco5550
Old 03-21-2007, 07:44 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Sounds like you might need a new master cylinder....if it is leaking out the back , then it will be leaking between it and the power booster.
Old 03-21-2007, 07:56 PM
69 chev
thanks henry i will check it out
Old 03-21-2007, 08:00 PM
Lost in the 60's
Wiki Edits: 4
My advice.....If you get a new master cylinder...get a new one...don't use re-built parts on your brake system just to save a few bucks.
Oil leak in 350 Chevy Ed Baltera Engine 18 07-29-2012 11:24 AM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Desperately need carb for a '69 Chevy 307 van onisland Engine 2 01-13-2007 11:12 PM
'69 Chevy Impala Disc conversion Impala Stuart Suspension - Brakes - Steering 8 09-11-2003 06:05 PM
69 chevy pu speedy Transmission - Rearend 4 11-12-2002 11:59 AM
