69 chevy c-20 body lift - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2009, 12:42 PM
I'm considering putting a 2 inch body lift on my 69 Chevy c-20 pickup to fit the new 33's I just put on the front. tires rub a little bit when I turn hard left. They clear just fine when I turn right, the alignment was just done, I know the body mounts are a bit worn...probably still the originals from 69. Looking at the truck, I can't figure this to be too difficult (just wish I had done it when I had everything apart to begin with! Ahh, If hindsight had foresight!!!)
Has anyone done a body lift on these truck before? Offer any advice and/or tips? (Besides plenty of cold beer in the fridge...thats a given at my place!!)
Thanks!
Chris
Old 03-16-2009, 02:50 PM
fast68's Avatar
likes chevy trucks & boobies
howdy there, is the front body centered?
might be off centered a little
i would do a measurement from the frame rail to both lower fender corners and see.
if not centered then loosen the rad suppport mounting bolts and center it
cant be much
you lifted a 4x2 ?
interesting.
not very common hehehe
good luck
Old 03-16-2009, 02:55 PM
Good thought! It did just come back from the body shop, so it could very well be off a little. I'll check it later. Havent lifted it yet, and if I do, it will be just enough to clear tires. It's not a 4x4 and I cant stand it when people jack thier trucks way up and forget they dont have that little drive shaft that goes to the FRONT of the truck!!!??
I've got mine at stock height, the 33's give it a nice, fat, mean truck look...
Old 03-16-2009, 06:23 PM
How bout that?
cant be much
you lifted a 4x2 ?
interesting.
good luck
19 1/2 on the driver side and 19 on the passenger side (thats the side that's rubbing) so it's off a 1/4 inch...I'll push it over later, but dont think that will entirely take the rub out...
Thanks!
Chris
59 Chevy truck body on 80-85 Chevy frame? texczech General Rodding Tech 11 08-18-2011 08:24 PM
Chevy Throttle Body Question ChevyJim Engine 17 03-29-2008 03:50 PM
69 Chevy Van Brake Set-up Slammit78 Suspension - Brakes - Steering 2 02-02-2006 06:12 AM
Classic Chevy Body Alignment Belair 57 Body - Exterior 3 01-16-2006 12:51 PM
Max valve lift (chevy) americanfreedoms Engine 3 06-24-2002 12:02 PM
