69 chevy rear end help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2006, 03:10 PM
I have a 69 chevy truck. I do not like the original gear ratio, its to low. I would like to go to get a better gear ratio rearend from the salvage yard that will help me get the best use out of my 350 engine. I have a set of 20's with 6 lugs. I would like a diifferent rear end that I can also use the same rims with. I need some advise.
Thanks
Old 08-07-2006, 10:10 PM
I think the 6-cylinder trucks from that era came with numerically higher gear ratios than the V-8 ones. Look for '63-'69 for 6-lug units that are the same width as yours. They went to a wider rear end sometime during the '70 model year, but both widths had the 6-lug pattern. 5-lug wheels started in '71.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
How to identify the year of a Chevy 10 bolt rear End? frankenvette Transmission - Rearend 2 04-07-2005 11:14 PM
rear end swap for 1950 chevy w/ 350 blake Transmission - Rearend 2 10-10-2004 09:51 AM
1951 Chevy Coupe Rear End Swap JLF-JLF Transmission - Rearend 14 04-12-2004 04:49 PM
96 Chevy PU Rear end howls tommytempest Transmission - Rearend 3 04-29-2003 02:49 PM
