Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 03-19-2002, 11:01 AM
tm454 tm454 is offline
Tazz
Cool 69 comaro brakes on 64 chevelle
Got a line on 69 comaro disc setup, was wondering if you have all the components, spindals,upper and lower arms,rotors and all, will this setup swap?
Old 04-02-2002, 03:33 PM
F-1Rodder's Avatar
F-1Rodder F-1Rodder is offline
Post re: 69 comaro brakes on 64 chevelle
Tip: go to your local library and find an ancient parts interchange manual for 64-69 or around that period. You will find that the part numbers are listed for each component of the steering system. This will guide you as to which vehicles are direct donors for your project. You may be able to just look at the parts and determine that they will work. I do know that the 69 camaro used a 2 piece spindle. I converted my 69 from drum to disc by using part of the 69 and part of the later series spindle to adapt the rotors to the drum spindle. You may also be able to get some information from a company like Master Power Brakes, Baer or Stainless Steel Brakes. You won't want to pay their prices, but they may give you enough informtation to get what you need accomplished.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
