69 corvette leanin large - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2005, 03:05 PM
My 69 bb corvette is leaning to the left and toward the rear. At first I thought the rear spring was shot, so I put a new heavy duty spring on- same thing still leans. To compensate, I have put rubber washers and tightened up the left side of the spring considerably: in fact, I've got the spring to the point where it's flat. I put a heavy duty rear end cover on, because I've always been afraid of the spring or the rearend cover it's mounted on might break. The body mounts look good. There is one body mount behind a little cover just in front of the rear wheel that I haven't looked at yet....My question is, do you think that it's safe to drive? I've been driving the car like this for 10+ years, but I'm afraid to really drive the car hard because of this. Is there a way to see if the frame is bent without taking the body off of the car?
Old 02-19-2005, 03:13 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
BB springs
It may be the front springs not the rear at all. Especially with the weight of the BB. On a flat surface, measure the the frame rails to the ground on all 4 corners. You may find the the front left spring is bad.
Old 04-15-2005, 11:22 PM
yes indeed
Thank you Bracketeer for suggesting the front springs---you were right!! New springs on the front and she's as level as the day she was born. It's amazing that the lean showed up in the rear. You are the man-thanks again!
Old 04-19-2005, 04:15 PM
Bracketeer, you're the man
You called it right---the weak front coil springs made the rear lean to the left----I replaced the front springs with 550 lb ones and it's nice and level--thanks a lot Bracketeer--now I can slide around some corners without fear
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 02:32 AM
69 corvette wiper nightmare! BYONDXTRME Electrical 6 11-24-2004 02:41 AM
what motors did '69 corvette heads come with? smlblcks10 Engine 1 12-01-2003 03:35 AM
69 corvette steering problem Suckingas Suspension - Brakes - Steering 2 12-26-2002 11:59 AM
