Originally Posted by RayCharles
I've got a vaccum leak either in the Carb or in the intake manifold. Decided to rebuild the carb first. Rebuilt it. Fuel gushing out top of carb. Did I misadjust the float?
You probably have something in the needle/seat or the floats are way off. JMO What carb is it you are working on ?
Go back and re-check the floats and make sure you got everything clean so that nothing is blocking the needle valve. JMO Simply re-check your work.
You should have verified where the vaccum leak was first IMHO.
Cole
