Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 firebird exhaust
Old 03-05-2004, 01:54 PM
36scsc 36scsc is offline
Last journal entry: Got the backside done (more or less)
There is no simple answer to your question but since you state that you are going to be doing little high speed/ high rpm stuff with it you may want to consider this one general rule of thumb....Smaller diameter pipes produce low- to mid-RPM torque and larger diameters produce mid- to high-RPM torque. Low rpm + big dia. exhaust = reduced velocity and more heat loss, neither of which you want. Bigger ain't always better.
